heater
Old Oct 11, 2006 | 09:51 PM
nissan tech 81's Avatar
nissan tech 81
Default heater
I am a Nissan Tech, but i can't figure out why i have no heat in my car?
I checked the coolant, and the heater hoses. It is a northern car, i am thinking the heater core could be plugged?
Any comments would be great.
Old Oct 12, 2006 | 04:39 PM
tomthedog's Avatar
tomthedog
Default RE: heater
if your fan speed and vent select ***** work ok check the cool/heat **** for bad connection or shorts. my 02 has no cable (just wires) controlling the ac/heat sys. might just not have any airflow going over the core. you should be able to put your hand behide the radio area (might have to pop a cover off) and feel some heat build up. maybe try a coolant flush? or discon the heater core from the coolant loop and run a water hose through the heater core to try and flush the core? let us know what's up, good luck.
Old Oct 12, 2006 | 06:39 PM
superstrat97's Avatar
superstrat97
Default RE: heater
you may have a broken blend door. if you have no coolant leaks, that may be your most likely cause
