96 Dodge Stratus Turbo, and rear disc brakes
Old Nov 2, 2006 | 11:45 PM
2.4 DOHC Demon's Avatar
2.4 DOHC Demon
Default 96 Dodge Stratus Turbo, and rear disc brakes
Hey,
First I was wondering, what fuel injectors do people use for when they turbo charge the 95-00 Dodge Stratii. Does the 2.4 DOHC engine share the same block as the 420A engine? Will a 420A turbo manifold fit the 2.4? Also has anybody heard of any installation of rear disc brakes for the 95-00 series? If so could you send me the information. Thanks alot for everything.
Old Nov 3, 2006 | 04:06 PM
BloodRed's Avatar
BloodRed
Default RE: 96 Dodge Stratus Turbo, and rear disc brakes
I would check on turbododge.com for info turbo dodges. The 2.4 is not the same block as the 420A. The 420A is a Mitusbishi 2.0L engine.
Old Nov 20, 2006 | 01:23 PM
cloudcar_racer's Avatar
cloudcar_racer
You should talk to Rich at Dreamspeed2.com about turbo charging a 2.4L and the rear disc brake converstion has been done several times before. I had plans to do the turbo and rear disc brake conversion when I had my 2.4L Plymouth Breeze. The Breeze got totaled and I bought a Stratus ES. The Strat came with factory all wheel discs and I plan to swap motors in the future.
Old Nov 24, 2006 | 03:54 PM
2.4 DOHC Demon
Yeah, I talk to Rich alot. He's helped me out alot. I left him an email recently, but it seems that he's busy because I havn't gotten a reply. He told me that the 420A manifold is going to be relying on luck to fit. He said some match the stratii but, others do not. I have a question about the Jet Performance Modules. Do you know any reviews on them? Can the module adjust the shift points, it says on the description but, I want to know if they do for sure. Also, do you know what size steel braided hoses the stratii use for brake lines? What year Stratus do the all disc brakes come on? Thanks alot for everything everybody.
