View Poll Results: A poll
Ignition Coil
33.33%
Fuel pump
0
0%
Plugs
0
0%
Faulty cylinder
0
0%
(IAC) Idle Air Control Valve
16.67%
(TPS) Throttle Position Sensor
50.00%
Alternator
0
0%
Fuel Filter
0
0%
Fuel Sending unit
0
0%
Air in Fuel line
0
0%
Voters: 6. You may not vote on this poll
EVERYONE PLEASE DO THIS POLL
Old Dec 7, 2006 | 06:25 PM
krs_si's Avatar
krs_si
Junior Member
Default EVERYONE PLEASE DO THIS POLL
Over the past month, many members on the site have asked about the problems with rough idle, car bucking, jerking or about to shut off after start up? I myself have been faced with the same problem and I even went to the dealer and they were no help. What do you guys think it could be? The says one thing and if thats not the problem then they end up charging you for something else. Someone has to know what is causing this problem. Its seem to be happening to a lot of 00-07 Stratus owners. Please Help us Pinpoint this problem.
Old Dec 8, 2006 | 04:53 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: EVERYONE PLEASE DO THIS POLL
when our 05 Stratus was doing it, we took it in and they did their check and everything and found that the TPS connections were coming loose...so they fixed and its fine...and it was under warrenty which was nice.
Old Dec 8, 2006 | 07:27 PM
TBNorge's Avatar
TBNorge
The last time I drove a car that was bucking, jerking and did not want to run after starting, it was bad fuel. Low rate fuel without enough detergents can cause the injectors to clog up. Don't see this on the list.
Try running a couple of tanks of good fuel through it with some extra cleaners.
Old Mar 18, 2007 | 12:46 AM
bbbbuddy's Avatar
bbbbuddy
My Strates is a pice of crap! I am.... Was a Moper Man!! I will never purchase a mopar agen...NEVER!!!![:@]
