changing front wheel bearing
Old Dec 17, 2006 | 04:10 PM
01indigoR/T's Avatar
01indigoR/T
Default changing front wheel bearing
how involved is it in removing the front wheel hub and bearing assembly? doesnt look too bad but i gotta change the thing
Old Dec 17, 2006 | 09:58 PM
2.4 DOHC Demon's Avatar
2.4 DOHC Demon
Default RE: changing front wheel bearing
I just replaced mine two weeks ago, and it was not hard at all...at the most thirty minutes. You have to remove the tire, brake caliper, rotor, and disconnect the lower control arm . It's not that hard. I hope this helps.
