Engine Swap Help
I have a 2002 R/T, I was wondering about any possible engine swaps that would be good in the car. Also what I am mainly looking for is if it is possible to stick the 3.5 liter in with a supercharger. Thanks for the help!
if its the same motor then should i just twin turbo the one i have, or does the motor out of the 3000GT's have more hp potential. also if that's the case can i do an awd swap to my car.
u might be able to get away with the twim turbo setup from the 3000gt im am sure u could do the awd conversion but that could prolly get pricey, but on the other hand it could be one of a kind cause i have not seen another with it done,
If you wanna stay half way economical about it strip the motor from an evo and weld some brackets and mounts into your engine bay as well as supports. The twin turbo would kill the stock rt motor because the 3000gt twin turbo vr4 has different internals and heads. Besides the stock rt internals are only good for about 10psi boost.
