Stratus Do It Yourself information
Old 07-17-2010, 03:15 AM
lancejonesmusic's Avatar
lancejonesmusic
lancejonesmusic is offline
Originally Posted by Monster0921
i have a question?? what is the spark plug gap on a 2005 dodge stratus sxt 2.4l 4 cylinder sohc??
i bought some NGK's from autozone and they were gapped fine out the box- recommended.
Old 12-20-2010, 02:08 AM
Hastings's Avatar
Hastings
Hastings is offline
Default Lost
Trying to find the Ambient Air Temperature Sensor on my 2005 Dodge Stratus . any clue where it would be located ? Off topic I know , just a shot in the dark here...
Old 01-13-2011, 04:10 PM
FrankTA2's Avatar
FrankTA2
FrankTA2 is offline
Default Link does not work
vBulletin Message
Sorry - no matches. Please try some different terms. The following words are either very common, too long, or too short and were not included in your search : OR
vBulletin Message
Link does not work
Old 02-17-2011, 08:17 PM
jimmyjoebob79's Avatar
jimmyjoebob79
jimmyjoebob79 is offline
Default Question
I have a 2.4 I'm in the process of rebuilding. I'm building the bottom half stronger with forged pistons and eagle rods etc. Going to do some head work to and put a bigger cam in and so on. What I was wondering, could I put both a supercharger on and a turbo? Trying too get as much horses that I can. Im going to get everything machined too. Just not sure about what asked..
Old 02-28-2011, 07:40 PM
crysto25's Avatar
crysto25
crysto25 is offline
can anybody send me a pic where to find that oil pressure switch for a 05 stratus? lol thanx
Old 03-07-2011, 07:17 PM
chrisg_ky's Avatar
chrisg_ky
chrisg_ky is offline
no you cant put a super charger and turbo on . one or the other
Old 03-07-2011, 11:16 PM
smokesxt's Avatar
smokesxt
smokesxt is offline
actually you can run both. superchargers are belt driven and add low end power (torque). turbos run off exhaust gas and generally build mid and high end power. on 4 cyl however pretty much useless. so which to choose depends on where you want the power.
Old 03-09-2011, 01:34 AM
Gknight's Avatar
Gknight
Gknight is offline
Default 2000 Stratus Panel lights out.
I bought a 2000 Stratus today and tonight learned that my light cluster does not work. Noticed the Headlamp Relay is missing. COuld this be culprit? Or more likely BCM or Switch assembly? Really appreciate any help. Thanks!
Old 03-19-2011, 02:12 PM
sprlgptrblt12@yahoo.com's Avatar
sprlgptrblt12@yahoo.com is offline
Default help me pease
need instructions on replacing 2000 stratus fuel pump.
Old 04-04-2011, 09:53 AM
vineugn's Avatar
vineugn
vineugn is offline
hello,
I have a 2001 dodge stratus with a 2.4 liter. The motor went out and I replaced it with a 2003 2.4 salvage yard motor. The problem I'm have is I'm only getting firing from the # 1 and 4 cylinders. # 3 & 2 are not firing. Needing answers on where and what I may need to do to solve this problem. I have compression, gas, but no spark from plup wires 2 and 3.
vince
Quick Reply: Stratus Do It Yourself information
