Stratus Do It Yourself information
Old Apr 4, 2011 | 02:36 PM
  #21
Twinreaper's Avatar
Twinreaper
I had a similar problem not too long ago but only affected one cylinder. I went to local yard and picked up a Coil Pack from a 96 Neon, and went ahead and replaced all the plugs and wires. Worked like a charm and haven't had any issues yet.
Old Apr 19, 2011 | 12:57 AM
  #22
jimmyjoebob79's Avatar
jimmyjoebob79
Well with my stratus I want to b fast in the 1/4 mile... So I wouldn't know what to do turbo or supercharger!
Old Apr 19, 2011 | 01:50 AM
  #23
jimmyjoebob79
I have a 2000 dodge stratus with a 2.4.. I was thinking of getting a magnaflow cat-back exhaust and I was wondering if this would fit http://www.streetperformance.com/par...313-15775.html
Old May 2, 2011 | 07:09 AM
  #24
bridge winters's Avatar
bridge winters
wheel fell off 2001 dodge stratus, the axle, ball joint & sway bar was replaced, now transmission has no gears? what is wrong? is transmission no good now?
Old May 2, 2011 | 07:12 AM
  #25
bridge winters
why after changing axle, ball joint, and sway bar does my transmission have any gears?
Old May 3, 2011 | 01:58 AM
  #26
matt72991's Avatar
matt72991
what year? and what transmission??
Old Jul 25, 2011 | 12:54 PM
  #27
mountainrider19's Avatar
mountainrider19
Default Wiring harness diagnosis or replacement?
*sigh* I have a 2002 Stratus 2.7L (wife's car). It has 150,000 miles overall but the engine was replaced a year ago with a re-manufactured engine (sludge monster got the other). It has performed very well for 25,000 miles. Recently it died on my wife...60 miles from home where she works of course...and the problem was determined to be the alternator which we replaced at an independent mechanic shop. About 1 mi. down the road it faltered and died again. The same mechanic determined that although the alternator was indeed bad, there apparently is a short in the wiring harness "somewhere"...blows fuses and fails to charge. I have yet to look at the car but his recommendation of dealer service seems like a financial death-knell to me. I have a modest amount of electrical savvy and at least know my way around a VOM. My question: Is it possible or logical to obtain and install an entire replacement wire harness or does it make sense to try to find the short wire-by-wire? Or should I bite what promises to be an enormous bullet and take it to a dealer? Please share your experience and suggestions! We still owe money on the car and can't just dump it...and actually like the car otherwise. Thanks!
Old Jul 25, 2011 | 07:18 PM
  #28
chumpo's Avatar
chumpo
on a 2000 stratus, if you apply pressurized air to the service port in the engine compartment for the vapor recovery system, what should happen ?
Old Aug 7, 2011 | 05:37 PM
  #29
MARCOA25's Avatar
MARCOA25
Help me ?????? Where is the ambient air temperature sensor on the stratus 2003, please.
Old Sep 2, 2011 | 03:10 PM
  #30
Rocket67's Avatar
Rocket67
Linky no workie. Wonder what was in there?
