Dodge Viper The almighty Dodge Viper. No matter the year, since it's arrival, the Dodge Viper has made even the most refined car enthusiasts drool. This sports car has it all from a sexy look to pavement shredding power.
Im back and Got a Few Qs
Old Sep 12, 2007 | 08:58 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Im back and Got a Few Qs
You will add about 100HP with those mods. Very little add with no cats vs high flow, but what you will do is reduce heat int he side sills with no cats vs high flows.
First generation SR (1992–1995)
Generation One
Viper RT/10
Production
1992–1995
Body style(s)
2-door roadster
Engine(s)
8.0L V10
400hp (298kW)465lbf·ft (630N·m)
Transmission(s)
6-speed manual
Wheelbase
96.2in
Length
175.1in
Width
75.7in
Height
44.0in
Curb weight
3400lb (1542kg)
The first prototype was tested in December 1989. It debuted in 1991 with two pre-production models as the pace car for the Indianapolis 500 when Dodge was forced to substitute it in place of the Japanese-built Stealth due to complaints from the UAW, and went on sale in January 1992 as the soft roofed RT/10 Roadster.
The centerpiece of the car was its engine. Originally designed for a truck platform and based on the Chrysler LA design, a division of the Chrysler Corporation revamped Dodge's cast-iron block V10 for the Viper by recasting the block and head in aluminum alloy. Some within Chrysler felt the pushrod two-valve design, while adequate for the truck application, was unsuitable for a performance car and suggested a more comprehensive redesign which would have included four valves per cylinder. Chrysler, however, was uncertain about the Viper's production costs and sales potential and so declined to provide the budget for the modification.
The engine produced 400 hp (298 kW) at 4600 rpm and 465 ft·lbf (630 N·m) of torque at 3600 rpm, and thanks to the long-gearing allowed by the torquey engine, provided surprising fuel economy at a claimed 21 mpg US (11.2 L/100 km) if driven sedately. The body was a tubular steel frame with resin transfer molding (RTM) fiberglass panels. Much of the suspension, following the manufacturer's "engine first" mantra, was sourced from the Dodge Dakota pickup. Typical of American performance car design, it had a front-mounted engine driving the rear wheels; it was also very light in respect to modern Ferrari's with a curb weight of 3,280 lb (1,488 kg) and lacked many modern driver aids such as traction control or anti-lock brakes. Car and Driver magazine referred to this generation as "the world's biggest Fat Boy Harley", and likened driving it to "playing ping pong with a Louisville Slugger baseball bat." Despite this, in straight line performance, it completed a quarter mile in 12.6 seconds and had a maximum speed of over 180 mph.
The car was also devoid of any real luxuries. Along with the absence of exterior door handles, the vehicle lacked windows and even a roof. Although a soft top cover was available, it was designed primarily for outdoor vehicle storage. In terms of interior space, the trunk was large enough for the rain cover and little else. Chrysler's purpose for the vehicle was clear in almost every aspect of its construction; from the unyielding bolstering of the seats to the side-exit exhaust that came with its own disclaimer against passenger injury. Performance came first, creature comforts last (if at all).
Performance:
0-60: 4.6 sec.
0-100: 9.1 sec.
quarter mile: 12.6 sec. @ 119 mph
top speed: 180+ (confirmed by Road and Track magazine / 1992)
700 ft slalom: over 65 mph
skidpad average g: .96
Old Sep 13, 2007 | 07:07 PM
Big_N_Bad's Avatar
Big_N_Bad
Thanks so your sayihng that with cats it will reduce the heat to the sill or no cats will reduce the heat to the sill thanks again man,
BNB
Old Sep 13, 2007 | 07:39 PM
CarGuyOhio's Avatar
CarGuyOhio
ORIGINAL: Big_N_Bad
BNB
High flow will reduce some vs stock. No cats will reduce even further.
Old Sep 13, 2007 | 09:56 PM
Big_N_Bad's Avatar
Big_N_Bad
You are the man
BNB
Old Sep 20, 2007 | 08:38 PM
Big_N_Bad's Avatar
Big_N_Bad
Hey 94, what are some mods that you can do that would produce some hefty gains out of The srt-10 truck. And if you had to get another one would you go with a quad cab or not. And would you recommend this truck, Thanks it has crossed my mind to get one of these also, I have been snake biten
BNB
Old Sep 21, 2007 | 09:45 PM
CarGuyOhio's Avatar
CarGuyOhio
https://dodgeforum.com/m_815298/tm.htm
Full exhaust, at a min replace the mids with 3" mids with high flow or no cats and of course cat back. Like the Viper the 4 cats on the SRT-10 is a bad thing.
If a QC you will need a PCM flash.
Anything you do that will give you any decent gains will cost at least $600, with a full exhaust pushing 2500-3000.
It is a buyers market on these trucks right now. You should be able to get a low mile truck for 25-29K.
