Dodge Viper The almighty Dodge Viper. No matter the year, since it's arrival, the Dodge Viper has made even the most refined car enthusiasts drool. This sports car has it all from a sexy look to pavement shredding power.
True speed!
Old Dec 8, 2005 | 06:08 PM
Rome sky's Avatar
Rome sky
Default RE: True speed!
2006 coupe=.39
2006 roadster=.40
Old Dec 8, 2005 | 06:13 PM
ViperGTS's Avatar
ViperGTS
Something doesn't sound right..
Where is your info coming from?
-Matt-
Old Dec 8, 2005 | 07:23 PM
Rome sky's Avatar
Rome sky
This is from Dodge, everything about any car I use is from the car company. In the way of Dimensions and such. So what doesn't sound right? The only think I had to assume on is the percent lost, and I think 10% is more than fair.
DIMENSIONS AND CAPACITIES(a)
Wheelbase 98.8 (2510)
Track, Front 61.6 (1565)
Track, Rear 60.9 (1547)
Overall Length 175.6 (4459)
Overall Width (at sills) 75.2 (1911)
Overall Height 48.6 (1234)
Ground Clearance 5.125 (130)
Curb Weight (estimated) 3,410 lbs. (1546 kg)
Weight Distribution F/R 49.4/50.6%
Frontal Area 19.3 sq. ft. (1.79 sq. m)
Drag Coefficient 0.39 (estimated)
Fuel Tank Capacity 18.5 gal. (70L)
INFORMATION PROVIDED BY DAIMLERCHRYSLER
highrevr/tflea's Avatar
highrevr/tflea
this has to do w/ the speedo being off like they test w/ motorcycles at high speeds...motorcycles are a lot more off in these cases tho. They can be off as much as 15 mph.
Old Dec 8, 2005 | 07:32 PM
Rome sky's Avatar
Rome sky
I was a little bit off on that and it does differ for each car depending on frontal area, and drag. Nevertheless a good rule of tumb if you don't want to use the equation is 5 mph=1hp for speeds above 190. With the viper I think it came to about 4=1.
Old Dec 8, 2005 | 07:39 PM
Rome sky's Avatar
Rome sky
More than likely you are right. THats why I believe in GPS and lazer with the midde being the true speed. Not many companies are testing that way, but I think Ferrari is one. A good example of that was there 550. Everyone was saying it would do over 200 but Ferrari said no 199.
Old Dec 8, 2005 | 09:03 PM
ViperGTS's Avatar
ViperGTS
The drag on the Viper.. no one here agrees with what it should be. It was a discussion in the past. The Viper needs to be more aerodynamic, not a moving brick..
-Matt-
Old Dec 8, 2005 | 11:11 PM
Rome sky's Avatar
Rome sky
I totally agree with you. The viper should have a lower coefficient, but all my numbers on the viper; I get from Dodge. If you look at the G35 coupe. It has a CD of about .29, and it makes no lift. THat is crazy to think about. One of the easiest ways Dodge could lower the vipers drag is to put a negitive lift plate on the viper. In other words coat the bottom of the car so that it is slick. That alone could drop the Cd by .05-.06 or so.
Old Dec 8, 2005 | 11:22 PM
dubvipers's Avatar
dubvipers
i was just wondering, who was drivin it? some 190lb guy?
Old Dec 8, 2005 | 11:32 PM
ViperGTS's Avatar
ViperGTS
190 is the estimated top speed, not weight.
-Matt-
