Dodge Viper The almighty Dodge Viper. No matter the year, since it's arrival, the Dodge Viper has made even the most refined car enthusiasts drool. This sports car has it all from a sexy look to pavement shredding power.
Crank Pully Issues 05 SRT-10
Old Apr 28, 2006 | 03:11 AM
rrjii2000's Avatar
rrjii2000
Default Crank Pully Issues 05 SRT-10
After hearing a funny noise under the hood, I investigate. Only to find my Main belt has spun off. when I try and replace it, I notice that the crank pulley is loose. So I torque it back on and replace the belt, fire her up, and it came loose again. this time I take it all the way off. The splines were completely stripped! The crank shaft was also rounded off. I've only had this car for about 1 year (3000 miles), and this was quite a suprise. Has anyone else experienced a similar problem?
Thanks,
Rob
Old Jun 2, 2006 | 11:07 PM
rrjii2000's Avatar
rrjii2000
Default RE: Crank Pully Issues 05 SRT-10
I crated the engine and shipped it back to the factory, luckely all will be covered by the waranty. So far they think it was a fartory defect and are replacing the crankshaft. I can't wait to get her back.
Rob
Old Jun 2, 2006 | 11:59 PM
CarGuyOhio's Avatar
CarGuyOhio
The SRT10 Ram has the same issue. You need to check the bolts while changing your oil. 130 ft/lb
Old Jun 23, 2006 | 05:07 PM
rrjii2000's Avatar
rrjii2000
Well I got her back today, finally. Everything seems to be running smoothly. They also said to periodicaly check the bolt.
Rob
