99 cummins mod
Old Jul 14, 2012 | 03:50 PM
99withflat's Avatar
99withflat
Default 99 cummins mod
I have heard you can put washers on the screws on the top of the injection pump on a 24 valve to increase the fuel flow, how complicated of a job is this? and what all do you need to do it , and what size washer does it take?
Old Jul 19, 2012 | 10:45 PM
99withflat's Avatar
99withflat
found a package to do it
Old Oct 9, 2012 | 11:30 PM
noonrock's Avatar
noonrock
Diesel owners, is it necessary to start out in first gear with an older Cummins powered five speed manual trans? Have a neighbor who winds it out in compound (?) each time she drives by. Is she dreaming of an ICL license or just stupid?
Old Oct 10, 2012 | 04:13 PM
99withflat's Avatar
99withflat
It sure isnt the best idea to do it, there really is no need to even use first gear depending on how its geared and if you have a load or not
Old Jan 29, 2013 | 06:42 PM
Jigabop's Avatar
Jigabop
first gear?! you mean the idle in traffic gear?!
I NEVER use first gear unless idling in traffic.
I start in second with 0 throttle...just let the clutch out and torque gets it rolling.
Old Jan 30, 2013 | 12:04 AM
scatpack_69's Avatar
scatpack_69
Ditto. Only use it when CRAWLING in traffic, or if you have a pretty hefty load behind you, it's good to use, less stress on the clutch
