electric problem
Old Apr 15, 2022 | 04:51 PM
stalhazelberg's Avatar
stalhazelberg
Exclamation electric problem
4WD crew cab, Hemi 5.7L V8 multi displacement VVT Laramie Longhorn, shows these problems:
usually within 2 miles, my whole dashboard shuts down for about 1 to 2 sec. after that everything will work again. It usually starts with the message power steering is missing. After that, the battery light on the dashboard usually comes on. Then everything works again to repeat everything after about a minute. I have also noticed that when the route planner is switched on via carplay, everything immediately stops. This repeats about 5 times after which nothing else is going on all day, regardless of whether I have stopped somewhere for a long time. Who can help me with this problem?
Old Apr 15, 2022 | 08:08 PM
You are in the wrong spot to get any help with this. You wanna be in the Ram forum, which gen depends on the year of your truck. Check the main section to see which subsection you need to be in. It's broken up by year.
