a few questions - sandblasters, welders, a/c
Can you recommend a good quality sandblaster I can use in my garage to strip the paint, and take the loose rust off.
I have some major rust issues, and I want to take the paint off and see where the rust is, so I can cut it out, and patch in some metal with a welder.
What type of welder do you recommend for doing both body work, and fabbing up custom bumpers, and able to weld on diffs.
Finally I will need to get a good paint gun, and a/c tank. What size electric air compressor do you suggest to use for both air tools, as well as paint.
