Exterior Modifications Talk about your rims, body kits, and other exterior mods here.
molding and emblem removal
Old Apr 5, 2008 | 05:43 PM
nmgrzyb's Avatar
nmgrzyb
Default molding and emblem removal
i need to know what works best for removing the emblems and side molding from my 05' magnum
Old Apr 15, 2008 | 11:20 PM
Avenger2NV's Avatar
Avenger2NV
Default RE: molding and emblem removal
Use dental floss or fishing line. Run it up and down like a saw underneatn the emdlem or molding. Once you get it odd use goof off or even WD-40 to remove the adhesive *sp* Then put a little wax on. Depending on how long they have been on you might see a "ghost" emblem. This will go away with time and cleaning.
Old Apr 28, 2008 | 12:57 AM
hemicide's Avatar
hemicide
you might try heating the emblem up lightly with a heat gun or torch first, then use fishing line. Dental floss tends to brake alot.
Old May 11, 2008 | 08:57 PM
nbstriker10's Avatar
nbstriker10
yea ive used a hair dryer to loosen up the tape or glue underneath then it usually just pops off... i used a flat head screwdriver wrapped in a cloth to avoid scratching the paint... its better then fishing line cause you can muscle it more with a tool then a thin string...
Old May 22, 2008 | 03:46 AM
Shibby927's Avatar
Shibby927
Emblems are tough you really can't get the adhesive hot enough behind them so you basically have to saw at the adhesive with the fishing line. Dental floss will not work. I was breaking fishing line on this stuff, so dental floss is a no go. Just saw at it carefully until you get the emblem off and then use an adhesive remover and a microfiber pad to get most of whatsleft off. If you can get your hands on a product called Graphix Gone Adhesive Remover this product works better than 3M and smells a ton better too, but I think you have to order it online.
Old May 22, 2008 | 07:31 AM
lunachik's Avatar
lunachik
I removed my badges yesterday, and I used a 2 inch plastic scraper that I got at pep boys. this is the 3rd time i've removed badges from a car, and the first time I used the fishing line and had excess adhesive left over.
with the plastic scraper, the majority of the glue is removed, and all you really gotta do is use some elbow grease with some goo gone to remove the rest.
Old May 23, 2008 | 04:11 AM
Shibby927's Avatar
Shibby927
Yeah the plastic scraper idea is a good one. Don't you need to get the emblem off first though to scrape the adhesive.
Old May 24, 2008 | 04:25 PM
nbstriker10
i wouldnt trust anything with the word "scraper" in the name against paint... it sounds like it could only end in disaster...
Old May 25, 2008 | 08:00 AM
Shibby927's Avatar
Shibby927
Nope, I used one on mine, not a single scratch. They make paint friendly scrapers.
Old Jun 18, 2008 | 03:45 AM
N30N's Avatar
N30N
ORIGINAL: Shibby927
true man.pep boys has a little white plastic one that works wonders on emblems.no scratch and no problems.i used it first to pop the emblems off and it didnt leave much residue.also try goo gone
