Heads for 98 360ci.
Old Sep 5, 2004 | 04:18 PM
98dodgeramsst's Avatar
98dodgeramsst
Default Heads for 98 360ci.
I have a 98 ram sst 360ci. and I want my heads redone, but the guy that I want to do it is a LT-1 man, can anyone porvide or tell me what the max specs are for a pretty much stock motor.
Old Sep 6, 2004 | 11:18 PM
moparturd's Avatar
moparturd
Default RE: Heads for 98 360ci.
Can you be more specific about what you want to do to the heads?
Old Sep 7, 2004 | 02:19 PM
98dodgeramsst
I need specific numbers foe porting them. What's the max I can go with a stock bottom half, or would I be better just buying Magnum heads.
Old Sep 7, 2004 | 05:31 PM
moparturd's Avatar
moparturd
The heads you have are Magnum heads if it's a 98 SST. You can get porting templates for them from MoPar. You can also get some kickass aluminum heads from Edelbrock for around 1300 bucks that outflow the stock heads. Knowing MoPar, they want at least that much for their version, without valves, springs, retainers, and locks.
Old Sep 8, 2004 | 04:00 PM
98dodgeramsst
Then can you tell me how much of a difference there is in stock heads and magnum heads. Also lead me somewhere so I can get my heads ported. My plan is to put fastman 52mm throttle body on port my heads and put 3" straight pipe all the way back.I want to get my truck in the low 14's in the quarter. Right now it's low 15's and I want to beat the ricers all running high 14's
Old Sep 8, 2004 | 07:00 PM
moparturd's Avatar
moparturd
I may be mistaken, but there is no such thing as stock vs. Magnum heads. The stock heads are Magnum heads. That is what makes the Magnum engine a Magnum engine. A good place for ported head service is Hughes engine.
http://www.hughesengines.com
Good luck.
Old Sep 10, 2004 | 03:20 AM
94ram4x4 5.9's Avatar
94ram4x4 5.9
definitely talk to someone at hughsengines!!!! They are a really big help with anything you want to know.....my buddy and I made an awesome motor out of his stock '99 Dakota R/T...very fast...
Old Sep 16, 2004 | 06:42 AM
98dodgeramsst
thanks i will check it out
Old Sep 17, 2004 | 09:08 AM
94ram4x4 5.9
Just in case you never found hughes(i misspelled it)
5.9 Fast Enough?
Old Sep 18, 2004 | 10:08 PM
98dodgeramsst
My plan is to port and polish my heads, bigger throttle body, and straight 3" exhaust. I need a mid to low 14 sec. run to shut up the ricers and mustangs.
