86 ramcharger problems
Old May 29, 2007 | 04:41 PM
HemiMan02's Avatar
HemiMan02
Default 86 ramcharger problems
I have a 4wd 86 ramcharger with a 5.9 motor w/carbuator that was rebuilt about a year ago.
The problem is that the truck will start and idle fine but when you take it out and you slow for a stop sign or light it will die. Then once you get it started again it will hesitate for a minute before it takes off. Does anyone have any ideas as to what the problem might be?
Thanks
Old May 31, 2007 | 12:42 AM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: 86 ramcharger problems
Check everything involving the fuel and air intake systems - Carb(idle screw, mixture screws, floats etc) , vaccum lines, EGR. Just do an inspection over everything you can get your hands on basically.
Old Jun 26, 2007 | 04:02 PM
charginram's Avatar
charginram
vacuum leaks?
Old Jul 1, 2007 | 06:52 PM
rebcharger's Avatar
rebcharger
If it smells of gas when this stop happens it could well be the float valves not closing properly. Lets excess fuel drizzle through and floods the plugs. How does it do for HC and CO at idle on a smog test? If they're high that points to the same.Ours R/Cis a '90 5.2 w/ TBI.
