Clear Coat Problem
Old Sep 22, 2004 | 12:24 AM
drumn911's Avatar
drumn911
Default Clear Coat Problem
Hey when i spray on my clear coat and when it dries, it dries cloudy!! I live in Florida where the humidity is high, is this the cause? im using aerosol cans...not the best but the best i could find for aersol..when it goes on wet u see it literally drying up cloudy..it kind of flashes...of course it has been raining all day too so im sure that didnt help? how do i get around the humidity? This is a pain in the ***!! now do i have to sand past the retarded clear coat or just sand with like 400 or 600 grit paper?? help!! If there is anyone that works for the fire department here and wanna trade duty t-shirts hit me up...thanks once again...
Old Sep 25, 2004 | 04:18 AM
BIGMOPAR's Avatar
BIGMOPAR
Default RE: Clear Coat Problem
may i ask why you are using aerosal clear are you touching up a damaged area? What type of Canned Clear is it a Cheap Krylon type or Professional grade Dupont or PPG canned clear? Yes if it is very humid or raining you will have problems with any type of painting/refinishing if using a Rattle can or any product you cannot change the Activator/reducer amount. In general a cheap "rattle can" Clear will dry hazy, i have never seen one look as good as a good clear shot out of a HVLP gun. I use only Dupont midrange Clear with a mid-temp reducer unless it's very muggy and i will use a Hot reducer along with a Sata HVLP digital 2 with a 1.3 tip Gun shoot a Fog coat to give the surface Tooth and wait about 15 minutes go back over with a double wet coat and be careful on side panels! i run about 18 psi on the final coat and the biggest mistake with clear is volume and speed! hope this helps!
[8D]
