What does this mean??
Old Jun 18, 2007 | 12:54 AM
soulbro361's Avatar
soulbro361
Default What does this mean??
I have a 2000 dodge ram single cab truck. For the past few months when I drive sometimes long distance my truck just cuts off on me. Where my milage shows the words " no bus" comes up. what does that mean?? If anyone knows what I'm talking about please help me out. Thanks
Old Jun 23, 2007 | 05:54 PM
dishdude2k's Avatar
dishdude2k
Default RE: What does this mean??
means it lost connection with the PCM.. sounds to me like u hit a bump and it rattled it a bit.. check connections on it..
Old Jun 23, 2007 | 09:59 PM
soulbro361's Avatar
soulbro361
But it doesn't always happen after I hit a bump or something. When it cuts off, it takes a while for it to start up again. When I try to turn it on thats when the "no bus" comes up. Do you think it may be my fuel pump getting ready to go out???
Old Jun 23, 2007 | 11:45 PM
jbotkin's Avatar
jbotkin
I have a 99 dakota with the exact same problem. I have done some research and everything points to a short in one of several sensors. So far have not been able to solve my problem. Nothing related to the fuel pump itself
Old Jun 24, 2007 | 02:19 AM
dhvaughan's Avatar
dhvaughan
if the no bus comes and goes, its most likely a loose connection. do a search on no bus for the locations of all the grounds - power steering bracket, under dash on drivers side, other places maybe firewall near pcm. also unplug and replug pcm several times to reseat all connections there. also CTM under dash to the right of the gas pedal (on a 01) its a black box about 4" x 3" x 1"
