2 more q's
Old Oct 10, 2004 | 11:33 PM
ramfan5.9's Avatar
ramfan5.9
Default 2 more q's
what are the trannys limited to for a topspeed on a 97 ram 1500 2x4 5.9 360
and
how bad is it if its bad atall for ur vehicle the hold the brakes and bring the rpms up to ~2000 on an auto tranny
thanx
Old Oct 11, 2004 | 12:38 AM
moparturd's Avatar
moparturd
Default RE: 2 more q's
Dude. I hope these answers are helping you out.
The top speed is more related to the rearend gear and RPM capabilities of the engine. There probably is an RPM limit of a tranny, but I'm not sure what it would be.
I wouldn't do it all the time. Eventually something will break. It's tough on the U-joints too.
Old Oct 11, 2004 | 04:36 AM
injmopar's Avatar
injmopar
I can not see the trans having any effect on the top speed. Unless you are also towing a load in overdrive. This will short the life of the OD.
I do not know about 97s, but Dodge use to have a limiter built into the computer. And for brake stands,what would life be with out a brake stand now and then.But full throttle ones are risky. If you brake anything in the drive line the trans will over run, and damage the sprag..
Old Oct 11, 2004 | 01:19 PM
ramfan5.9's Avatar
ramfan5.9
aite thanx man
