92 Ram Problem
Old Sep 5, 2007 | 05:15 PM
dergani's Avatar
dergani
Default 92 Ram Problem
I took apart my 92 Dodge ram to rebuild some of the engine and clean it up and I put the thing back together and the starter will not turn at all.
New, charged battery and all of the wires hooked up where they are supposed to be. The lights work, as do wiper, radio and all the internals.
The starter worked fine before I took it apart so it cant be bad. Turned the crankshaft and it moves, cant be seized up. I thought i heard the
starter move a very tiny "click" but then nothing. Only thing i may have done different was run the ground for the neg wire from battery to a diferent bolt hole on engine.
Also I took of the started to get the oilpan of and put it back on, could the gears to flywheel be not meshing properly? A little help would be great.
Old Sep 5, 2007 | 05:16 PM
dergani's Avatar
dergani
Default RE: 92 Ram Problem
Its a 318 LA with the electronic fuel injection, I had also replaced the ASD/Fuel relays when i rebuilt it
Old Sep 5, 2007 | 05:52 PM
SrtHemi's Avatar
SrtHemi
I wouldnt think it would be the starter meshing if its the same starter. Could try moving the ground wire back or to a diffrent place to see what happens, if that doesnt help it could be the selonoid.
