spark knock at high rpms
Old Nov 1, 2004 | 08:53 PM
Old_Ironhead's Avatar
Old_Ironhead
Default spark knock at high rpms
I have a 2000 R/T Durango 5.9,it idles very smooth and accelerates strong,at high rpms and under a stain(going up a bridge,etc)it develops a spark knock and seems to lose power.The scan tool sends no codes whatsoever.This truck has been very well maintained and has just over 61k miles on it.I know there is a service bulletin on the intake manifold gaskets leaking.Before I take the top of the engine apart I was wondering if anyone else has had this problem and if it was anything other than the manifold gaskets?
thanks
Bill
Old Nov 2, 2004 | 03:59 PM
moparturd's Avatar
moparturd
Default RE: spark knock at high rpms
Sounds like you have some carbon build-up on the pistons. The dealer has some spray cleaner that you can put in the cylinder that will lossen the deposits.
Old Nov 2, 2004 | 06:59 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
wouldnt lower octane gas cause this also? what octane do you use?
Old Nov 2, 2004 | 07:03 PM
moparturd's Avatar
moparturd
BadStratRT.
Do you have a part # on the cleaner. I remember reading a bunch of stuff on this over the past few years with the 318/360.
Old Nov 2, 2004 | 08:58 PM
Old_Ironhead
I only use 93 octane Amoco gold in it.Anything else and the knocking will drive you crazy.
Old Nov 3, 2004 | 11:38 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
4318001AB-5.75/can
Old Nov 3, 2004 | 11:17 PM
Old_Ironhead
I think I found the problem,a cracked pcv hose.I thought I heard a vacuum leak,hopefully that was it.I'm still going to use cleaner though,thanks BadStratRT
