Need help identifying AC Compressor part
Old Sep 25, 2007 | 02:40 PM
rgreen103's Avatar
rgreen103
Default Need help identifying AC Compressor part
Can anyone out there tell me what this part is? I assume it is some type of AC Compressor coil. I just replaced the AC compressor on my 2001 Dodge stratus 2.4 ltr with a reconditioned compressor and it did not include this component. I used this old component on the new compressor and I have verified voltage at the main plug but there is no voltage at the clutch. I also measured continuity of this component and it reads as if the circuit is open. I am thinking this component is bad unless I am totally off base.
[IMG]local://upfiles/62384/6C9A23A4064642E9814CC9C4C526EA73.jpg[/IMG]
[IMG]local://upfiles/62384/253919B14EE844D584E70D091D797BCB.jpg[/IMG]
Old Oct 4, 2007 | 08:50 PM
dodgeTEXAS's Avatar
dodgeTEXAS
Default RE: Need help identifying AC Compressor part
that is the a/c pressure switch, high pressure cut off. these tend to go out. its a switch that is open when there is too much or not enough pressure to save the compressor from failure. it will show open because the switch defaults open.
