C.A.I.
Old Nov 6, 2004 | 01:21 AM
ELFEZ's Avatar
ELFEZ
Default C.A.I.
i AM UP IN THE AIR BETWEEN THE AIRAID FIPK AND THE AFE COLD AIR INTAKES. I KNOW THAT THE AFE REQUIRES THE REMOVAL OF THE STOCK RESONATOR BOX(MARKED HEMI 5.7), BUT DOES THE AIRAID KIT AS WELL? I'D HATE TO LOSE THE LOOK OF THE BADGE UNDER THE HOOD, BUT UNDERSTAND SACRAFICES FOR PERFORMANCE.
Old Nov 7, 2004 | 05:41 PM
casper's Avatar
casper
Default RE: C.A.I.
Yeah I could understand not wanting to lose the badge, but just an idea, the CAI will look real nice, and you can take the badge off the resonator box and bring it to a local sign shop and have them do a nice badge to put on the CAI that looks the same.
Old Nov 7, 2004 | 07:35 PM
moparturd's Avatar
moparturd
Default RE: C.A.I.
Just make sure you get one with an adequate tubing size to serve the Hemi.
Old Nov 7, 2004 | 11:11 PM
ELFEZ's Avatar
ELFEZ
Default RE: C.A.I.
i'M NOT SURE OF THE EXACT SIZE, 3.5", I THINK...
I FIGURE THAT EITHER THE K & N OR THE AFE ARE MANUFACTURED TO THE PROPER SIZE. RIGHT? ANY PERFORMANCE PREFERENCES OUT THERE? DON'T WANT TO WASTE MONEY, JUST GET THE BEST TO BEGIN WITH. THAT'S WHY I'M DRIVIN' A HEMI RAM!
Old Nov 7, 2004 | 11:57 PM
moparturd's Avatar
moparturd
Default RE: C.A.I.
3.5" would be perfect. Some less expensive kits I've seen cut corners on tubing size, but those are good. The TB size is 3.375" inside diameter. Hope this helps.
Old Nov 8, 2004 | 01:30 AM
ELFEZ's Avatar
ELFEZ
Default RE: C.A.I.
AFTER FURTHER REVIEW OF THE SITE I'VE FOUND SOME GOOD INFO. IS THE AFE REALLY PRONE TO TAKING A BATH UNDER BACK ROAD CONDITIONS,, WET SANDY ROADS? I LIKE THE INSULATION WRAP,COLD AIR WISE, BUT THE K&N'S CHROME TUBE CONCERNS ME A LITTLE WITH ENGINE HEAT PENETRATING. DOESN'T THE SFE PRODUCE BETTER DYNO RESULTS AS WELL?
Old Nov 14, 2004 | 02:07 AM
casper's Avatar
casper
Default RE: C.A.I.
I don't know about it taking a bath, my CAI is 8-10 inches off the ground and I have a neon, a truck should be much higher up. It should be fine for normal driving, I would not use it if you were gonna off-road or mud bog or anything like that.
Old Nov 23, 2004 | 04:37 AM
TJW815's Avatar
TJW815
Default RE: C.A.I.
u would have to totally submerge the filter in water to make your engine hydro-lock, but if it worries you, you can get a bypass valve for it the runs inline to the tb, so that if it sucks up water it pulls air from the bypass instead.
Old Nov 23, 2004 | 11:38 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: C.A.I.
i have a full length CAI in my RT, and sitting still, the filter is about 5 inches from the ground.i have driven in Hard rains, hit big puddles..so on...and no hydrolock issues. ive only ever met one person who has expereinced hydrolock.
Old Nov 24, 2004 | 11:14 AM
moparturd's Avatar
moparturd
Default RE: C.A.I.
I just finished installing the Lowe's Home Improvement CAI on my Hemi. I used 4" dryer duct, the metal piping not the flexible ducting, and modified the box to accept the 4" adapter. The air pick-up is at the base of the rad support, so it's definitely in the coldest air. There was a noticable improvement.
