fuel filler hose tutorial
Old Oct 9, 2007 | 02:59 PM
batman13's Avatar
batman13
Default fuel filler hose tutorial
the problem,
the solution
start by removing the fuel cap
then, remove the four(4) screws surrounding the hose and pulling the hose down below the body
You may need to keep the screws
(NOTE, now is a good time to finish your cigarette)
then, to remove hose from tank, simply...
after that, to put the new hoses on, you pull the collar back, and push the hose onto the tank, you wil feel a clunk when it settles into place
and put the fill end back up into its hole, use a screw to hold it in place after twisting to get it straight
reinstall four(4) screws
Reinstall cap
This is why I decided to paint mine
Enjoy
Old Oct 9, 2007 | 03:08 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: fuel filler hose tutorial
looks like you had fun, and glad someone else figured it out before i needed it(probably never will)
Old Oct 9, 2007 | 03:40 PM
DAKNBLK's Avatar
DAKNBLK
Nice write up!! I think you were wise to changethat out!
How much $$was the part?
Old Oct 9, 2007 | 03:59 PM
Chris's Avatar
Chris
Thank you for the write-up! I moved it togeneral tech in the DIY section.
Old Oct 10, 2007 | 12:38 PM
batman13's Avatar
batman13
ORIGINAL: DAKNBLK
I had to change it, gas leaked every time i got it[:'(]
it cost $75 @ autopartspeople.com
