95 1 tond dually
Old Sep 25, 2007 | 08:24 PM
1tondually's Avatar
1tondually
Default 95 1 tond dually
I have a 95 1 ton dually with a V10 and a boss plow on the front. I was under the dash today and did something to lose my head lights. I have parking lights but no head lights. I checked the fuse under the hood and it was fine. I verfied that I do not have any power going to my head light slect switch. Is there another fuse that I am missing that I might have blowen. With this having a boss plow on it I am not sure were the power comes from. Does it come from the head light switch itself and if so how touchy are they. Is it possible I damaged the head light switch itself? any help would be great I do not have any books or schmatics for this truck
Old Sep 30, 2007 | 09:09 PM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: 95 1 tond dually
I can some schematics this week n see whats what under the dash.
Old Oct 2, 2007 | 08:54 PM
1tondually's Avatar
1tondually
Thanks Hell... any schmatics would be great it would help me out
Old Oct 4, 2007 | 05:26 PM
dodgeTEXAS's Avatar
dodgeTEXAS
is it a tilt column??
Old Oct 4, 2007 | 06:08 PM
1tondually's Avatar
1tondually
No it's not a tilt
Old Oct 4, 2007 | 08:25 PM
dodgeTEXAS's Avatar
dodgeTEXAS
first check fuse 6 40 amp in the pdc. if ok check b1 rd/lg for the headlamp switch. should have voltage b/c you say the park lamps work. next i need to know if you have high beams. if so you may have a failed headlamp dimmer switch. most cases i have done have been either the headlamp switch on the dimmer switch.
Old Oct 5, 2007 | 09:12 PM
1tondually's Avatar
1tondually
I had checked all the fuses under the hood and in the dash and everything was fine. Now tonight when I went out to look at it the head lights worked........that makes me more nervous the if they didn't work at all. When the lights were working I rattled all the wires under the dash and under the hood and they were fine. Is it poosible that I have a stuck relay that came unstuck? or is it a bad connection somewere?
Old Oct 10, 2007 | 04:29 PM
HellaciousHemi
Sorry i havent gotten them schematics yet, If you have a library by you theymight have Mitchell on Demand or Alldata online. Mitchell has better wiring diagrams though. Otherwords a chilton manual might have them also. But it looks like you are gettin some help so I hope ya find the problem soon.
