98 Advenger Turn Signal Issue
Old Oct 10, 2007 | 11:32 PM
gt pony 1's Avatar
gt pony 1
Default 98 Advenger Turn Signal Issue
This is my 16 year old daughters car.
I have not yet had a chance to really look at what is wrong.
She was driving to school today and put her left signal on and its stuck on.
The right signal is now not working at all.
I had to remove the fuse to get it to stop.
You can move the lever to turn on the right but it will not work all that happens is the left stays flashing.
I am thinking its the switch in the steering column.
Has anyone else had this issue?
Is the switch or lever hard to change?
Thanks
Old Oct 11, 2007 | 04:06 PM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: 98 Advenger Turn Signal Issue
The lever/switch is easy. You just need to remove the cover of the column and there should be 2, maybe 3small screws or bolts holding it in place. Detach the wiring and replace.
