alternator help!!!
Old Oct 17, 2007 | 05:35 PM
foursevenram02's Avatar
foursevenram02
Default alternator help!!!
alternator just went out on my 02 dodge ram, was gonna see if anyone had step-by-step instructions or any tips on replacing this...thanks a lot
Old Oct 18, 2007 | 08:49 PM
Parts/Service's Avatar
Parts/Service
Default RE: alternator help!!!
REMOVAL
3.7L / 4.7L
WARNING: DISCONNECT NEGATIVE CABLE FROM BATTERY BEFORE REMOVING BATTERY OUTPUT WIRE (B+ WIRE) FROM GENERATOR. FAILURE TO DO SO CAN RESULT IN INJURY OR DAMAGE TO ELECTRICAL SYSTEM.
[ol][*]Disconnect negative battery cable at battery.[*]Remove generator drive belt. Refer to 7, Cooling System for procedure.[*]Unsnap plastic insulator cap from B+ output terminal (GENERATOR CONNECTORS - 3.7L / 4.7L).[*]Remove B+ terminal mounting nut at rear of generator (GENERATOR CONNECTORS - 3.7L / 4.7L). Disconnect terminal from generator.[*]Disconnect field wire connector at rear of generator (GENERATOR CONNECTORS - 3.7L / 4.7L) by pushing on connector tab.[*]Remove 1 rear vertical generator mounting bolt (REMOVE / INSTALL GENERATOR - 3.7L / 4.7L).[*]Remove 2 front horizontal generator mounting bolts (REMOVE / INSTALL GENERATOR - 3.7L / 4.7L).[*]Remove generator from vehicle.[/ol]
