New Member-Low Oil Pressure w/cold start
Old Nov 14, 2007 | 10:45 AM
04dkota's Avatar
04dkota
Default New Member-Low Oil Pressure w/cold start
I'm new to the forum, but I need a little help with my 2004 Dakota 4.7L. When I start my truck after letting it sit outside in the cold for an extended period of time the oil pressure stays at zero and the check engine light comes on. If I shut the engine off and turn it back on the oil pressure reachesnormal level on the pressure gagehowever it is a little slower than it would in warmer temperatures. I use 5W30 oil and replace the oil filter when changing the oil every 3500-4000 miles. Any thoughts on why this would happen and what I need to do to fix this?
Old Nov 14, 2007 | 03:24 PM
teva_feet's Avatar
teva_feet
Default RE: New Member-Low Oil Pressure w/cold start
thinner oil?
bit of a discussion on the factory recommended oil (5w20 vs 5w30) here:
https://dodgeforum.com/m_1023044/tm.htm
Old Nov 14, 2007 | 08:47 PM
dishdude2k's Avatar
dishdude2k
sounds like the sensor is cold.. and u gotta give it a 'kickstart' .. try changing out the pressure sensor
Old Nov 15, 2007 | 04:17 PM
04dkota's Avatar
04dkota
Thanks, I'll check it out.
