P0522 Durango not cranking
Old Nov 28, 2007 | 03:09 PM
topnotchint's Avatar
topnotchint
Default P0522 Durango not cranking
Hi,
I have a 2005 4.7 Durango sitting in my front yard, and it will not crank. I recently had a new fuel tank and pump installed about a month ago. Now it acts like the fuel pump is out again. I had a friend scan it and it pulled a P0522 for the Engine Oil Pressure Sensor/Switch Circuit Low Voltage. Could this be related the fuel pump in any way or is it a completely seperate problem? Any advice would be greatly apreciated. Thanks.
Old Nov 28, 2007 | 06:44 PM
dishdude2k's Avatar
dishdude2k
Default RE: P0522 Durango not cranking
oil pressure has nothing to do with fuel.. its a seperate problem.. what i WOULD do .. is check wiring on the pressure sensor .. make sure its not damaged.. or unplugged.. im sure.. the newer they are.. the more 'safety' devices they have.. and if it thinks there is no oil pressure.. it might shut down..
Old Jan 15, 2008 | 11:19 AM
clops79's Avatar
clops79
check battery and cable connections if battery low wil give volt codes and maybee not crank. question was wont crank? correct
