crankshaft positionig sensor
Old Nov 23, 2004 | 02:45 PM
andresram's Avatar
andresram
Default crankshaft positionig sensor
were the heck is it located????
Old Nov 23, 2004 | 02:46 PM
GMsucks's Avatar
GMsucks
Default RE: crankshaft positionig sensor
ORIGINAL: andresram
On what?
Old Nov 24, 2004 | 10:46 AM
Snafu's Avatar
Snafu
If it's for that '96 Ram you asked about earlier, which I'm assuming is a safe bet, it's on the back of the motor. If it's the 5.9L gas motor (360), again a safe bet, it's on the passenger side rear of the motor toward the top, between two of the bellhousing bolts that hold the transmission to the engine block. There's a notch on the top of your transmission bellhousing and the sensor is inside there. You'll see the wires coming thru the opening. On the bellhousing of the engine block there are 2 small bolts (takes an M12 or 1/2" socket I believe) holding the sensor bracket onto the engine. Take these bolts out, pull the sensor up thru the notch in the transimssion bellhousing, and unplug from the harness on top of the motor, just on the drivers side of the distributor. Installation of the new sensor is the opposite (obviously). It's kinda a pain in the *** cause there's not a whole lot of room to work.
Now, if it's a 5.9L Cummins Diesel (kinda a longshot, but could be), it's either right next to or behind your starter, I don't remember for sure.
Old Nov 24, 2004 | 11:04 AM
Snafu's Avatar
Snafu
Forgot I had pictures from my transmission swap project. Red circle shows the CPS. This is on a 5.9L (360) gas motor. Hope it helps.
Old Nov 24, 2004 | 11:10 AM
moparturd's Avatar
moparturd
Man. I thought I wasn't going to learn anything today.[sm=thanx.gif]
Gotta love those mopar rear main seals.
Old Nov 24, 2004 | 11:29 AM
Snafu's Avatar
Snafu
I probably should have changed that seal when I had the trans out, but it's not leaking on the ground so screw it. I already had my hands full converting over to the manual trans. Still isn't completely done, but I've been driving it for over a month now as it is.
