heat wont work on a 97 conversion van
Old Nov 26, 2004 | 05:55 PM
BLD's Avatar
BLD
Default heat wont work on a 97 conversion van
i got these dadge van thats taken me to hell and back and recently my trusty heat went out.. its not a coolant issue..
The control panel no longer clicked fom hot to cold, it just stuck, so i took it out and noticed the control wire was bent up and not realy doin what its spose to.. I followed the control wire to the lil doo hicky which it controls under the hood.. i understand that this wire basicaly turns a **** to a specific position depending on how hot or cold you wish it to blow.. So i figured i would turn it manully to the position it would be in if i were to crank it to high heat and that didnt seem to do it.. Even as i turn this **** to full heat i still get room temp air..
Any ideas?
Old Nov 26, 2004 | 05:58 PM
BLD's Avatar
BLD
Default RE: heat wont work on a 97 conversion van
Also.. the air certainly gets cooler when i turn the **** to where it would be had the control wire been working.. so its doin kinda whats its spose to be doin, it just aint gettin hot..
Old Nov 26, 2004 | 07:54 PM
moparturd's Avatar
moparturd
What year van are you talking about. If you're manually operating the valve under the hood, sounds like maybe the heater core could be clogged.
