deciphering codes and where to start?
Old Jan 18, 2008 | 06:11 PM
helipilot's Avatar
helipilot
Default deciphering codes and where to start?
Ok i got my codes they are 12,13,27,54,17. but i don't understand the 12 code i havnt disconnected the batterysince i put it in like 2 yrs ago?
Old Jan 23, 2008 | 04:16 PM
Sticky Sam's Avatar
Sticky Sam
Default RE: deciphering codes and where to start?
What vehical is this stuff from ? Engine size, model year, how many pots, diesel/petrol ? If you buy a Haynes manual, all the codes will be in it !
Old Jan 23, 2008 | 04:59 PM
bad venge's Avatar
bad venge
Section Moderator
It stores codes, and files the newest on top ... or you can have the codes cleared then see what pops up ...
13
No change in MAP from start to run
Harness and connector / Replace MAP sensor
27
Injector control circuit
Harness and connector / Injectors
54
No cam signal at PCM
Check harness and connector / Check camshaft sensor
17
Engine is cold too long
Engine cooland temperature sensor circuit and connector / Engine coolant temperature sensor / Thermostat
17
Closed loop temperature not reached (M/T)
Engine coolant temperature sensor circuit and connector / Engine coolant sensor / Thermostat
