Will not idle, sometimes. Heellllppp
Old Jan 24, 2008 | 12:07 PM
G_Allen0421's Avatar
G_Allen0421
Default Will not idle, sometimes. Heellllppp
I have a 2000 1500 5.9. For the past month she sometimes won't idle on her own. When I start up, it seems to drag, then catches up. I have to press gas pedal a little. Then other times, it drags, then starts up and runs OK. I had meter put to it and fellow said I had bad battery. However, it has never run down, and has good lights at night. One friend said it could be a bad negative battery cable. Another said could be alternater, another said could be idle sensor, another said starter going bad. Please help me.
Old Jan 24, 2008 | 12:14 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Will not idle, sometimes. Heellllppp
It would sound like the Idle Air Controller or dirt in the Intake plenum ... I'd try to give it a seafoam treatment and see if that cleans things up ...
Old Feb 15, 2008 | 11:28 PM
dishdude2k's Avatar
dishdude2k
its the battery.. mine did the exact same thing.. and i replaced the battery... runs like brand new
