oil pressure sending unit
Old Jan 24, 2008 | 01:02 PM
1baddak's Avatar
1baddak
Default oil pressure sending unit
This may sound silly but my oil sending unit started leaking, so i installed a new one. my old one always stayed about 1/2 the way up, even before it started to leak. My new one almost pegs the needle,and in less than 5 miles i developed a leak in the side of my oil filter(fram).a pin hole but it sure sprayed all over my oil pan.what could have caused this big change??this is a stroked 340 with about 8000 miles on it.
Old Jan 24, 2008 | 06:00 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: oil pressure sending unit
I'd get a mechanical gauge and install it in the port and see what PSI it says ...
Are you sure you got the correct Oil sender as they have different values for them ...
Do you think the motors building excessive pressure causing the hole in the oil filter???
Old Jan 25, 2008 | 10:19 AM
1baddak's Avatar
1baddak
It may well be the wrong one, I got it at auto zone.and from a know nothing clerk.I was watching the screen and it said it was the right one.Funny it said with gauge and she told me i got a gauge with it. ha Mine has a gauge and light.I put a new mopar filter on it and it did all right.I might try a mech gauge today.thanks.
Old Jan 28, 2008 | 03:14 PM
1baddak's Avatar
1baddak
Finally got the oil pressure checked with a mech. gauge.It was about 75 lbs idealing reved it up a little and it went up just past 80. so i guess the unit is ok.no more leaks anyway hooray.
Old Jan 30, 2008 | 11:11 PM
moe7404's Avatar
moe7404
moe in wichita ks
DO NOT use fram oil filters. use purolator pure one. my 2001 dak v 6 uses a pl14670.
be sure its the pure one. i dont have the room to tell about all the research ive done on oil and filters. but it sound like your engine has to much oil pressure.
