ABS Wheel Sensors
Old Mar 7, 2008 | 10:50 PM
RedRam05's Avatar
RedRam05
Default ABS Wheel Sensors
What type ABS wheel sensor (magneto-resistive or variable reluctance) is used on the front wheels of the 2005 Dodge Ramhemi truck? TIA
Old Mar 8, 2008 | 10:56 AM
Parts/Service's Avatar
Parts/Service
Default RE: ABS Wheel Sensors
The Wheel Speed Sensor consists of a magnet surrounded by windings from a single strand of wire . The sensor sends a small AC signal to the ABM. This signal is generated by magnetic induction. The magnetic induction is created when a toothed sensor ring (exciter ring or tone wheel) passes the stationary magnetic WSS.
Old Mar 8, 2008 | 01:28 PM
RedRam05's Avatar
RedRam05
Thanks for the reply!
It is my understanding that the magnetic induction sensor such as you described is a passive device that is not very accurate until the wheel speed reaches a reasonable value (ie, 10-20 mph). This was adequate for early ABS systems , but when more sophisticated stability/tractioncontrol systems were needed, a very accurate (down to zero wheel speed) active type of magneto-resistive sensor was required. I was wondering whether any of the newer Dodge cars/trucks (such as my 2005 Ram 1500) had converted to these new wheel sensors?
