IAC motor?
Old Mar 29, 2008 | 06:26 PM
randypape's Avatar
randypape
Default IAC motor?
how far should the pintle of the iac motor retract when tested cold? the book says it should be in more than an inch when installing it . mine's out about 3/4 in and when i turn on the key to check it it doesn't move? thanks Randy
Old Mar 30, 2008 | 02:04 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: IAC motor?
What motor /Car/ Truck ??? Are you installing a new one or trying to check an old one ???
Old Mar 30, 2008 | 08:17 PM
randypape's Avatar
randypape
1998 dodge stratus and i was checking the original iac motor in this car. it has 140,000 miles on it. i took out the iac motor but before i did, i sprayed intake and idle control cleaner into the throttle body and into the iac ports. this car doesn't seem to have what would be a fast idle when i first start it up. i checked the map,coolant temp,TPS sensors with my fluke multi meter and all appeared good. i read where i can check the iac motor by doing a vacuum test. i will try that next. thanks for any ideas or advice. Randy
