abs bleeding. no drb or whatever
Old Apr 28, 2008 | 11:19 PM
Nick Bain's Avatar
Nick Bain
Default RE: abs bleeding. no drb or whatever
JUST GOT THEhand pump in the mail. do those decrease the chance for air to get in?
Old Apr 29, 2008 | 09:57 PM
moparborn's Avatar
moparborn
Yes,just make sure to keep the fluid topped off.
Old May 2, 2008 | 12:52 AM
Nick Bain's Avatar
Nick Bain
oh I remeber starting the car to turn the front wheels to get at the bleeders is that what ****ed it up?
Old May 27, 2008 | 10:38 PM
Nick Bain's Avatar
Nick Bain
bump
Old May 28, 2008 | 12:22 AM
tom01973's Avatar
tom01973
sounds like you have a warped rotor.use the vacuum pump like suggested above and in the sequence above and you should be ok.I would drill out the broken bleeder valve and replace it.it's the only way to get all the air out.
Old Jun 1, 2008 | 12:09 AM
Nick Bain's Avatar
Nick Bain
update: car stops evenly. no more vibs. kind of fixed itself. bled brakes again. pedal still almost goes to the floor, what gives.
Old Jun 1, 2008 | 07:04 PM
tom01973's Avatar
tom01973
you are getting air in the system somewhere.check for leaks around the wheel cylinders and the rubber lines going to the front calipers.
Old Jun 7, 2008 | 12:25 AM
Nick Bain's Avatar
Nick Bain
their are no leaks that we could see. could their be some type of internal leak?
Old Jun 7, 2008 | 06:11 PM
moparborn's Avatar
moparborn
If there are no leaks in the system,the master might be going.
How does the pedal feel,spongy or firm?
If you pump the pedal a few times how does it feel?
