abs bleeding. no drb or whatever
Old Apr 12, 2008 | 07:02 AM
Nick Bain's Avatar
Nick Bain
Default abs bleeding. no drb or whatever
can a home mechanic without a computer do a proper brake job without the abs computer bleed or would thatF things up?
Old Apr 12, 2008 | 07:16 PM
moparborn's Avatar
moparborn
Default RE: abs bleeding. no drb or whatever
When you compress the cylinders,do it by opening the bleeders and you will be fine.
Old Apr 12, 2008 | 09:01 PM
Nick Bain's Avatar
Nick Bain
uh oh! The wheel cylinders on the driver side drum had to go in to get the new shoes on because the old shoes were down to the bone. I had to opena rustyhose mount that was pinching the line.So did that back up to much fluid into the system and ruin everything?
here is some info on my problem.
https://dodgeforum.com/m_1266193/tm.htm
Old Apr 13, 2008 | 01:15 PM
moparborn's Avatar
moparborn
Probable not but if air got in you might have to do some bleeding,how do the brakes feel?
Old Apr 14, 2008 | 01:45 AM
Nick Bain's Avatar
Nick Bain
i've been told it takes more pedal depression than before which doesn't make sense to me because now the cyclinders are further in on the one side. and there are vibrations
Old Apr 14, 2008 | 10:30 PM
moparborn's Avatar
moparborn
If you have to press the pedal further now,there might be air in the system.
Are the vibrations new,is it when applying the brakes.
Old Apr 16, 2008 | 09:32 AM
Nick Bain's Avatar
Nick Bain
yes its only when applying the brakes
Old Apr 16, 2008 | 10:54 PM
moparborn's Avatar
moparborn
You should go back and recheck assemble on all four corners.
Vibration in the steering wheel could be front,in the seat could be back.
Old Apr 18, 2008 | 09:39 PM
Nick Bain's Avatar
Nick Bain
well I just bled the brakes like it said to in the service manual.which happened to be misprinted and told of two different wheel sequences but that shouldn't be a huge deal. I also broke a bleeder at the front so I just used the line attach bolt.
So now the pedal travel is even worse wtf?????????????? [:'(][:@][:@][:@]. It goes almost to the floor before the brakes grab.
I noticed the fluid in the line that was pinched was nasty dirty.
Old Apr 18, 2008 | 11:50 PM
moparborn's Avatar
moparborn
Start at the right rear brake,then left rear,then right front,then left front,keep the master full.If you can use a hand vacuum bleeder,much easier.
