tranny oil
Old May 1, 2008 | 06:46 AM
boostedhks's Avatar
boostedhks
Default tranny oil
helo , i kind of added too much transmission oil to my 2001 dodge neon.. how bad is this ? how could i drain it out to add just the amount needed ? and where is the transmission filter if any ( never saw it)
Old May 3, 2008 | 11:22 PM
bvil's Avatar
bvil
Default RE: tranny oil
How much was it over filled (personally) anything close to a quart over makes me a little nervous so I usually drain it out anything under a half of a quart I’ll leave and have had on problems. If you want to drain it, some models will have a drain plug located on the transmission oil pan if however you don’t see one then the pan will more then likely have to be unbolted and drain that method (remember though that once the pan is unbolted you’ll have to replace the gasket) I have also drain some back out before using a siphoning kit and running the hose down the fill tube (that is if there is no screen or the filter isn’t in the way) and the filter is usually located on the bottom of the transmission inside the pan.
Old May 11, 2008 | 02:41 PM
hydrashocker's Avatar
hydrashocker
Basiclly,
You drop the pan and inside is the filter.
