Brake and AC PRoblems PLS HELP!
Old May 1, 2008 | 03:48 PM
hemisp0rtN's Avatar
hemisp0rtN
Default Brake and AC PRoblems PLS HELP!
Hello, recently i took my truck to Goodyear to get new tires, when they called me with a list of things needing to be fixed AKA trying to rip me a new one. Wanted $190 to change the brakes >.< well i did it myself for around 80$. Well everything was fine, and about a week later when i brake my rear end shakes very bad, as my steering wheel and brake pedal does also. I was told my "rotors" are warped but i just had them turned not long ago. Could it be air in my lines? or anything i could check to see, or fix myself? I really dont trust to many people with my vehicle. The other things is about 3 months ago When i turn my AC/heat on Full blast, it runs full blast but nothin comes out of the vents, could a door be stuck not allowing airflow? Or is there something to check for on this also?(the lights on the AC switches went out at the same time also). Any help is greatly appreciated. Thanks
Old May 3, 2008 | 10:20 AM
tom01973's Avatar
tom01973
Default RE: Brake and AC PRoblems PLS HELP!
sounds like your rotors are warped.replace them and torque all lug nuts equally.if you dont then you are more likely to warp them again.check the fuses for the a/c.sounds like a blend door motorcraped out but don't quote me on that.i worked on a honda cr-v that did something similiar to this.had to replace blend door motor.
