94 Sundance stalled now won't start.Help :(
Old May 8, 2008 | 10:07 AM
thergirl66's Avatar
thergirl66
Default 94 Sundance stalled now won't start.Help :(
Hello, I have a 94 Sundance.I was driving home and all of a sudden it just died.No noise, no nothing.when I tried to restart it, it turned over but will not start.I did the key dance and I got a code of 33 which has to do with the air conditioner.Does anyone have any ideas where I should start???? I would appreciate your help.
Thanks, Rita
I don't know if this helps but I have been letting the gas get pretty low (almost on e) lately before I put gas in it. Could this have caused a problem??? I had just put gas in it before this happend so I know I wasn't out of gas.
Thanks again, Rita
Old May 8, 2008 | 08:47 PM
bvil's Avatar
bvil
Default RE: 94 Sundance stalled now won't start.Help :(
Have you checked the fuel filter sometimes the filter can become clog from debris. It’s really just the process of elimination usually the first thing I do is check for trouble codes, depending on what the computer says then its spark at the end of the plug wires, fuel pressure, etc (use caution when checking for a spark on the plug wires it can deliver dangerous high voltage)
Hope this helps
Old May 9, 2008 | 10:10 AM
thergirl66's Avatar
thergirl66
Thanks, I will check the fuel filter.Do you know where it is and what I am looking for? (sorry i'm a female and know little about cars)
Thanks, Rita
Old May 13, 2008 | 11:42 AM
hydrashocker's Avatar
hydrashocker
I think that one is on the top side of the tank next to the rear axel. I would replace it first. If that doesn't work I would go to the pump.
The filter should look like this.
[IMG]local://upfiles/17201/173B57E0BF3F4E75AE67E3BD5ED2C99F.jpg[/IMG]
