ATF +4 or gear oil ?
Old Jan 16, 2005 | 04:19 PM
Shazaam's Avatar
Shazaam
Default ATF +4 or gear oil ?
I have a 2002 Neon sxt , manual transaxle. The CHILTON manual calls for ATF+4 automatic Tranny fluid instead of standard transaxle fluid.
Is this correct ? The ATF+4 does not seem to me to be the correct choice. Thanks in advance.
Old Jan 16, 2005 | 05:31 PM
Snafu's Avatar
Snafu
Default RE: ATF +4 or gear oil ?
Don't know about your application in particular, but most aluminum case manual transmisions do take ATF. I'm pretty sure yours would too.
Old Jan 16, 2005 | 05:49 PM
casper's Avatar
casper
I just did mine in my 98 and it called for the +4, its been in there for a while and runs fine.
Old Jan 16, 2005 | 07:06 PM
Shazaam's Avatar
Shazaam
Thanks , I am no newbie to car repair but somethings still escape me. I like the ocassional challenge to my knowledge.
You may be laughing because it is such a basic question, but when you learn anything by OJT you miss the finer skills of a school trained tech.
Thanks again !
Old Jan 16, 2005 | 07:43 PM
Snafu's Avatar
Snafu
I was surprised the first time I ran into a manual trans that required ATF. They've been doing it in the aluminum case manuals for about 20 years or so. I just didn't run into one until '99. Glad we could help.
Old Jan 16, 2005 | 08:01 PM
casper's Avatar
casper
Yeah no question is a stupid one if its asked. I thought it odd too, I have always used gear oil.
Old Jan 16, 2005 | 10:54 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I didn't realize you could use ATF in the power steering until a few years ago.....
Old Jan 16, 2005 | 11:04 PM
Snafu's Avatar
Snafu
Well, you CAN use it in the power steering, but you really shouldn't. It'll work, but it contains detergents that deteriorate the seals in your power steering system. Very much bad things happen after a couple years. The pump on my blazer is so bad now I'm using 90 weight in it...
Old Jan 16, 2005 | 11:14 PM
casper's Avatar
casper
ORIGINAL: Snafu
Yeah I learned that the hard way too.
Old Jan 20, 2005 | 02:25 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: dustyloins
that's what the bmw calls for... the pump is leaking to.
