AC problems 2001 Ram 5.2l
Old Jun 18, 2008 | 11:02 AM
cakley's Avatar
cakley
Junior Member
Default AC problems 2001 Ram 5.2l
I bought a used Ram. A/C comp wouldn't kick on. Freon PSI was too high and it was lowered. Then the compressor would kick on PSI would rise to above normal rangecompressor would kick off. Freon was removed to lower PSI. Now compressor will not even kick on and PSI is in correct range.[]
Old Jun 21, 2008 | 01:09 PM
cakley's Avatar
cakley
Junior Member
Default RE: AC problems 2001 Ram 5.2l
Jumped the compressor at the relay box. Then lowerd the pressure. Now it still cycles from 5psi to 45psi and kicks off in about 5 seconds per cycle.
What do I look for next?
