95 Ram 360 v8 with engine problems
Old Jul 13, 2008 | 01:30 PM
95DodgeRam2500's Avatar
95DodgeRam2500
Default 95 Ram 360 v8 with engine problems
I Have a 1995 Ram 2500 with a 360 (Z code engine) that has a mysterious engine problem. It hesitates at first on acceleration, then if you quickly let off the throttle it gets worse, or sometimes dies. It also hesitates badly when you are trying to drive slowly (like in a drive through, or a parking lot), and when trying to reverse. The problem seems to be stronger when the truck is at full running temp. It also seems to lope or buck (if that makes any sense) while at crusing speeds(most noticable at or around 45mph, then again around 60mph) almost like it is hesitating.
I have replaced the fuel pump assembly, installed a new O2 Sensor, replaced the PCV valve, Installed a new reinforced intake plenum cover (from Hughes) along with new intake gaskets, checked my MAP and TPS sensors, Checked that all my injectors are working correctly and ohm correctly, replaced my spark plugs/wires/cap & rotor, ran sea foam (2 cans) in the fuel, and another full can through the vacuum lines/intake manifold. None of this did a thing, I still have all the original problems. Oh, and I have no check engine light on either.
Has anyone experienced a problem like this, or know what might be causing my nightmare?
Thank You
Old Jul 13, 2008 | 03:30 PM
moe7404's Avatar
moe7404
Default RE: 95 Ram 360 v8 with engine problems
moe in wichita ks
my 01 dak was doing about the same thing but not at the higher speeds as yours. i got some carb cleaner and sprayed down the thorttle plates while reving the engine to keep it from dieing. it helped a lot but didnt totaly strighten it out, it improved by 80%. i think what happens is that there is reverison in the intake manifold putting carbon on the throttle plates. good kuck
Old Jul 13, 2008 | 07:39 PM
bad venge's Avatar
bad venge
Section Moderator
Seafoam the intake tract ....
