O2 sensor?
Old Jan 25, 2005 | 11:02 AM
lonasindi's Avatar
lonasindi
Default O2 sensor?
this morning my car just threw a check engine light at me:
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
how critical do you suppose that thing is? I figure at worst it might affect my fuel mileage, but I could be wrong I suppose. Think I should have someone else drive to kokomo after school today (60mi round trip)?
Old Jan 25, 2005 | 02:14 PM
casper's Avatar
casper
Default RE: O2 sensor?
ORIGINAL: lonasindi
critical, not at all. PITA yeah. replace the sensor and reset the PCM, should fix it.
Old Jan 25, 2005 | 06:07 PM
02dakota's Avatar
02dakota
Actually its fairly important. And most definately will affect performance. The PCM will determine fuel strategy by use of that sensor. For example, if reading low voltage says to the PCM..."lots of oxygen" the PCM will correct by adding fuel. If high voltage says "not a lot of oxygen" it takes away fuel. It does this to try to maintain center (high/low switching). Yours may end up running too lean or too fat.
Old Jan 25, 2005 | 06:48 PM
GMsucks's Avatar
GMsucks
ORIGINAL: 02dakota
Not on the rear sensor though. The rear sensor is used to determine catalyst efficiency, that is all.
A failed sensor 2 on either bank will not cause a false rich or lean condition.
Old Jan 25, 2005 | 06:50 PM
casper's Avatar
casper
ORIGINAL: 02dakota
Yeah thats true, but for a short period of time it won't do any damage. If its the 2nd one there is no problem at all, cept for a clogged cat after a while.
Old Jan 25, 2005 | 06:56 PM
02dakota's Avatar
02dakota
Bank 1 sensor 2....ooooops...sorry guys, It's Tuesday.
Old Jan 25, 2005 | 08:29 PM
lonasindi's Avatar
lonasindi
eh, I've got an appointment to get it fixed thursday, it'll all be good.
