Removing rear rotors on 2002 Dodge Ram, Help needed!!!
Any big secret to removing the rear rotors on my 2002 Dodge Ram Truck? I have beat the heck out of them with a small hand sledge and they won't budge. Any help apprecitated.
Mine were also difficult to remove. I shot some WD-40 (or similar) thru the openings by the lug nuts and tapped in various spots before a good hard hit broke them loose. I didn't mind hitting hard as I was replacing the rotors.
_______________________________
Heard what happen at Autopartswarehouse.com
Drive Safely and Smile Freely.
OK obvious question E brake off ???
Some rotors have small threaded holes between the lugs that you can thread in small bolts to force the rotors loose
A large three armed gear puller can be tightened down hard and then start hitting it hard
