No Lo Beams
Old Feb 7, 2005 | 11:47 PM
Garner007's Avatar
Garner007
Default No Lo Beams
I have a 2001 3500 Diesel. I have seen a couple of posts about headlight, and wonder if my problem is the same as some of them. I have high beams, but no low beams. Is this most likely the headlight switch, or could there be some other problem. The bulbs are fine, btw.
Thanks ...
Old Feb 8, 2005 | 10:38 AM
moparturd's Avatar
moparturd
Default RE: No Lo Beams
Does sound like a switch problem to me.
Old Feb 11, 2005 | 01:22 AM
dd94unit's Avatar
dd94unit
Okay does your toggle wok when you pull it out?
When you say you have hi beams, does when you pull it back does it stick andwork on its own? Or do you need to hold it back?
Old Feb 11, 2005 | 12:39 PM
Garner007's Avatar
Garner007
When i turn the high beams on, they work on their own, i dont have to hold them back. Also, the fog lights work, as well as the running lights.
Old Feb 11, 2005 | 02:48 PM
Snafu's Avatar
Snafu
When you try to switch to low beams, do your high beams stay on or turn off? The switch is in the column, sounds like either it is bad, or you have a bad wire somewhere.
