Stalling
Old Mar 5, 2005 | 12:24 AM
ArkHunter's Avatar
ArkHunter
Default Stalling
Hello, I have a 96 1500 4x4 with a 5.9. It has started to die when you come to a stop, when running it's great but come to a stop or sometimes just take your foot off the gas and it dies. Any suggestions Thanks Jim
Old Mar 5, 2005 | 03:59 AM
casper's Avatar
casper
Default RE: Stalling
Are you throwing any codes? Do a tune up. Plugs, wires, injector cleaner, air filter.
Old Mar 5, 2005 | 05:00 AM
ArkHunter's Avatar
ArkHunter
Its not throwing any codes up so I was not sure what it was.
Old Mar 5, 2005 | 05:03 AM
justaocboy's Avatar
justaocboy
just need a throttle body service,you need to clean the pintle and bore in the throttle body,then reset
the value,(number of steps) on the throttle body,all good after that!!!!!!!
Old Mar 5, 2005 | 05:58 AM
ArkHunter's Avatar
ArkHunter
How do you reset? If I take the throttle body off clean it out real good and disconnect the battery to reset? Thanks Jim
Old Mar 8, 2005 | 01:06 AM
ArkHunter's Avatar
ArkHunter
I replaced plugs, wires, cap, rotor, egr valve, air filter and removed & cleaned the throttle body along with replacing vacuum lines. Problem solved. Thanks For all the help. Jim Rivas
