93 PLYMOUTH A/C PROBLEM
Old May 4, 2005 | 02:45 AM
Magnumguy's Avatar
Magnumguy
Default 93 PLYMOUTH A/C PROBLEM
Air was working when I bought the car, (about a month ago), noticed recently the cooling fan doesn't work, and also the a/c compressor doesn't either.
Done so far:
Jumpered the lowpressure a/c switch, and changed out all circuit breakers w/known good used ones. Also changed the temp coolant sensor. Still now fan doens't work nor does the a/c compressor. System has a suitable charge of freon, but not fully charged. Shouldn't matter since I've jumpered the l.p. switch. Also, disconnected and reattached all connections in wire harnesses.
Suggestions?
Old May 4, 2005 | 02:14 PM
moparturd's Avatar
moparturd
Default RE: 93 PLYMOUTH A/C PROBLEM
Is there power across the system when you are putting your jumpers in?
Old May 18, 2005 | 11:53 PM
HemiRam's Avatar
HemiRam
Did you try replacing the cooling fan relay? That might keep the a/c from coming on if its bad.
