Headlamps one dim one bright
Old May 8, 2005 | 03:50 PM
Lights's Avatar
Lights
Default Headlamps one dim one bright
I have a 1999 Dodge Durango with one bright headlamp and one dim. I tried looking for a short, faulty switch, or even bad bulb. I have not been able to locate the relay switch or cause. Does anyone know where to find the relay switch, determin if the headlamp switch is good or bad and anything at all.
I have power on both sides of the "left side headlamp fuse", in the engine compartment if I install the bulb on that side. It will also cause the right side to dim if the bulb is on.
If I remove the bulb in the left side it will turn the right side off from dim.
When I say dim I do not mean low from high just dim as in weak.
If anyone can make any suggestions or recommendations it would be extremely apreciated. My next task is to locate an A/C leak. I have my hands full and broke. Thaks read you soon.
Old May 18, 2005 | 11:50 PM
HemiRam's Avatar
HemiRam
Default RE: Headlamps one dim one bright
Try checking all your grounds under the hood espeilly the headlight grounds. A bad ground will cause exactly that problem.
